We have recently had our heating system upgraded (new radiators and conversion from gravity hot water to fully pumped system). In doing this we took the opportunity to have the heating zoned for upstairs/downstairs.
Everything works well but I would welcome thoughts on the following:
1. No room stat was installed for the upstairs zone! Stat downstairs controls downstairs zone only. Upstairs is either on or off at the programmer, rooms controlled with TRVs
2. The existing 28mm HW flow pipe was converted to combined feed and vent (with approx 4m horizontal run.) 28mm HW return retained as such. New HW flow pipe added (15mm). Is this OK? Does it compensate for the 28mm return? Is it to prevent the HW ‘robbing’ the heating supply (22mm)?
3. Pump overrun can be 20-30 minutes? Would this be due to the short bypass circuit (boiler instructions recommend min 4m – actual length is just over 3m)
Potterton Profile boiler. Horstmann 3 channel programmer. 3 x 2 port valves. TRVs on all radiators.
