- Joined
- 7 Sep 2022
- Messages
- 4,845
- Reaction score
- 1,411
- Country
Me too, and I gave up on my microzoning. I can see how someone might want a room to be warmer than others, and I'd probably look to do that with adjusting flow rates on the manifold rather than a bucketload of thermostats and zone valves. Works well albeit accidentally for our WC; the flow rate is set too high for the length of loop and I've never corrected it because everyone appreciates the room being a bit warmer it seemsThe concept of employing buffer tanks to try and make microzoning work with a heat pump seems nonsensical to me
Other family members think in the most incredible peck, as the nagging to turn lights off, flush toilets, put crap away etc is constantwhat other family members think of having to close doors all the time
If I was into microzoning I'd just fit decent door closers like barymatic damped jamb ones and have one less thing to bark about
As in tweaking flow rates so it runs all the time, at a level that replaces heat lost from the house? I wonder if that leads to more frequent defrost needs, versus being able to run at times of day when defrosting is unnecessarykeeping heat pumps running continuously
Agree, and our place seems to have a low enough heat loss that it running occasionally to bring the slab up a few degrees works well. Most the time our heat pump isn't runningand actually the cheapest way of running one, is for it to be turned off
Our heating is generally active Dec to Feb, cooling occasionally active in summer, but it's not very effective to cool a slab, and the ceilings are full of acoustic wool so the fairly useless spreader plates are even more so for coolingIn October for example I'll use a home assistant automation to turn it off when the indoor temp reaches a certain level
Somewhere I've got a year's data logged from a ct clamp on the Hp supply, I should dig it out.. I expect it fires up for a few hours a day. I look at the HP display every time I pass it (in the hall) and anecdotally it is seldom showing the "heat pump on" symbol. It also displays the return temp, and for a flow of 26, that is usually around 21 to 24, which gives me an idea of when it's due to knock offBetween Mid Nov and Feb/March though ours is running pretty much all of the time
Don't forget, in unfavourable conditions (humid, and between 0 and 7 degrees or so) some of that running may just be a defrostalbeit it will cycle roughly once an hour in slightly milder weather
