Right-angled 3/8" BSP screw adapter?
9 Mar 2011
Gloucestershire
I have a Quooker tap and naturally as they are european, everything is in 3/8.
The tap tail is a 3/8 screw with fibre washer which screws onto a 3/8 isolation valve.
It is a little taught, so I'd like to put a right angled adapter onto the 3/8 isolation valve so that the tap tail connects directly down onto it rather than bending through a nasty angle.
Does anybody know if such a thing exists? I've had a good look but don't seem to be able to find anything which makes me think I might be missing something...
You can get a 3/8th BSP street elbow that is male x female and will do what you want.
I saw that, but thought that might be more suited to taper type joints where you also use ptfe tape, rather than one that a tap connector screws onto with a fibre washer?
