Car revs question
16 Sep 2006
Fife
I've never been one to take my car to higher revs when driving. By higher I mean venturing anywhere near the red line.
However have bought a 2015 1.8 Honda Civic auto petrol (10 years old, 140bhp, 142ps at 6500 revs). Whilst the car is totally fine when pulling away from junctions and for daily driving, I'm having to virtually floor it (kickdown) to get any decent acceleration e.g. when entering a dual carriageway or when wanting to increase speed to overtake. Even then it's not great. Having said that I came from a 2.0tdi Seat Leon that had great lower torque. I miss it for that.
The rev counter on my dash goes to 8k with the red zone starting just after 6.5k. If I take the car to 4k revs and then ease off, that's giving me good enough acceleration.
I don't want to be hard on the engine, I want this car to last me a good few years. Given it's 10 years old, do you reckon I'm ok taking it to 4k under kickdown conditions on a regular-ish basis?
You'll be fine. Do what you have to do to achieve what you need to achieve. Different engines have different "characters". Some give their best at low revs, others at high. Hondas are notoriously "revvy". You won't hurt it as long as you stay blow the redline. My old Italian car is 37 years old with over 150,000 miles on it and still gets "redlined" pretty much every time I go out in it. Doesn't seem to have done it any harm so far!
I was always told that running a car at low revs for years is not good for the engine.
Engines are designed to go up in revs.
Not constantly of course, but a blast near the red line sometimes, doesn't do any harm, in fact it helps.
I used my sister's fiat Punto last summer.
Slow and without any guts.
By the end of the holiday, it felt more alive and quick.
Even my sister noticed it.
Is it a V-Tech engine? These have a reputation for being revvers
Bloke in the local has a nice, older 911,which he's spent tens of thousands on in restoration.
He says that running in should be fine across are range, not 1500 miles at a steady rpm.
I. e. don't thrash it, but don't trundle it either.
Nor me, but occasionally, I like to let it fly. Modern cars, include limiters on the engine speed, so you cannot over-rev the engine. It will not start bouncing the valves, like cars of old.
I now drive a modern diesel, with masses of torque, but my first experience of a diesel, decades ago, was of an older type of diesel. I swapped from my higher reving petrol, to the diesel, driving it 300 miles on the motorway - I just couldn't get any speed out of it at all, because I had it in mind, to keep the revs low, too low. I had it down there all week, and I learned how to make it go. On the way back to home, it went much faster.
Yeah I miss the diesel for oomph and fuel economy. I'm averaging just over 30mpg on the Civic, I never closely monitored what I was getting on the Leon but I reckon it was 50+mpg.
I'll be keeping this for a good few years but next time I change I'll need to get something with some oomph and turn of speed again.
Have a Volvo diesel , economy model , even at 70mph revs are below 2000rpm.
Same here, I find I mostly run mine between 1000 and 2000rpm, it's a bit of a monster if I get it to 3000rpm, and leaves any following vehicles way behind. 50+ mpg most of the time, on a run.
Meh... A 3 litre Guiseppe Busso-designed V6, that's what you need. Docile, torquey (for a petrol engine) and tractable from 1000 to 4000 RPM, and then a howling banshee that pulls all the way to the redline between 4000 and 6000! Best of both worlds.
Of course, for the real win...
...a nice electric motor that's so smooth you won't even be able to tell whether it's doing 100 RPM or 10,000 RPM and torque that makes the gruntiest of diesels look like mopeds!:p
