Square O rings?
4 May 2026
I need to replace the O rings on my Reginox Elbe (2017) mixer tap. I was sent some round profile ones that fit ok but seem too wide to fit back in tap socket. The original ones seem more square but I'm failing to find replacements. Can you tell me from the pic of current ones if these are square? or round and worn?
As Harry says. But failing that, it might be worth trying some suitably-sized round-section O rings.
The manufacturer can supply them but they want £9 inc p&p which is extortionate.
Lidl often sell a box of various sizes of o rings, for half of that. Worth trying round ones, which if they prove to thick, a too small one stretched in place, will make it thinner.
I assume you earn the minimum wage? That's not even an hour at work to have the right part and know it'll work, how much time that you don't get paid for will you waste trying to find another solution that may not work?
Yes 9 quid seems alot for 2 o rings but life's too short to spend time looking for another solution to save maybe a fiver
It’s possible to pay 7 quid for a cup of coffee from Starbucks
If the o-rings are a solution to the problem, and mean you don’t have to spend hundreds replacing a tap/hiring plumber etc, 9 quid might not be unreasonable for a solution that turns up at your house
I was appalled to see that loft roll insulation has gone up 50% since about 4 weeks ago - state of the world alas, thanks Trump (10 years ago it was a tenner a roll, a month ago 24 quid, which amazed me enough, but to have then called into wickes and been lifted 36 quid for a roll.. wow)
If you can DIY it then just change the tap.
Unless you can get them locally then you will have to pay P & P so I doubt you will save much, if anything
Yes I did the same trick. The best fit was too fat to get the swan neck back in so a smaller ring stretched to fit worked. But that eventually failed as it was working beyond it's limit as it was working very streached
It's OK paying £9 for the correct item, but buying and making do with an O ring kit, if it works, you then have a stock to cover future repairs, should they be needed. I fixed our kitchen tap spout around a decade ago, which had an odd shaped seal, lubricating it with a bit of grease - it has been fine ever since.
I'd already bought the ones from TAP MAGICIAN on CountryFan's link above but they are too wide. I've tried thinner and smaller ones from a 'kit' but same problem. I don't mind paying if they are the correct ones but wasting money on wrong ones isn't fun.
How much are the correct washers each?
Buy ten and sell the rest to cover P&P.
Presumably you have searched for “square profile O rings” and the like.
But as said, until they closed down, I used to travel across town to buy from a local rubber specialist (oh er!) and risk a parking fine or buy an on street ticket. Way more costly than £9.
Which is why I suggested you change the tap if you can DIY it. You are more often than not on a hiding to nothing with things like cartridges and o rings.
