contrails (chemtrails)
Status
Not open for further replies.
Look up - can you see trails that go from horizon to horizon - are they staying in the air and just slowly spreading out. Or do you have blue sky with short lived short length trails.
You are describing aircraft con-trails.
There is zero evidence to support anything of the contrary. In fact, an article recently posted up on here, explains in detail, how ridiculous the suggestion that commercial aircraft spray chem-trails actually is. You would need to be extremely stoopid to believe in the notion, too.
Well, where I am the sky is a milky white colour all over. Just looked at FlightRadar and there's hardly been a plane over me apart from 2 Diamond Twin Stars and an air ambulance. I'm pretty certain what I can see are clouds
The milky white is classic results after they have been over a few hours ago
The argument is that its different atmospheric conditions -- do you see horizon to horizon trails or is it now milky white
What do think happens to the hundreds of thousands of people organising this, when they breathe it in.
Who says its designed to be breathed in - and no its doesn’t need thousands to be involved, you haven’t been paying attention.
What is?
There is no argument. Read the article. It's akin to believing in the tooth fairy. It would barely make the the first wrung of 'the most infantile stoopid things to believe in' ladder. Yet here we are.
So what is it doing....?......And yes it would need many,nany,many people, all sworn to secrecy.
Some say its to reduce the streangth of the sun - which it does when it has spread out to form a milky blanket. Some say the cocktail of elements within is to enable certain military communications, some say its to poison us - although that may just be a side affect of the first two.
That is the standard lazy debunker trope. Have you seen the latest UFO disclosure around the Apollo 11 and 12 missions kept secret for 50 years - people have been called conspiracy theorists for years and now its been released it seems they were right all along and it was kept secrete for 50 years quite easily.
What do you mean "what is" -- do you even know what thread you are posting in
There is nothing to believe in -- just look up which you refused to do
What do you think?
Incidentally: Military communications that rely on condensation on the air? What is this the 1920s? Is it a method to confise carrier pigeons? Some people will repeat the most stupid ****.
Ummm....no. It's a perfectly natural thing called clouds. Apparantly they occur all over the world and have been doing so from way back before manned flight was possible. You'll be saying next that old coal fired powerstation cooling towers used to emit the same chemicals and now that they have gone planes have taken over.
Status
