contrails (chemtrails)
Status
Not open for further replies.
They aren't.
So the conditions are not the same all over today and yet there are no conditions anywhere that will produce the chemtrail signature trail.
There are none today because they are not doing it today
This is not the logical smack down you seem to think it is.
1) prove there are no contrails today.
2) prove there are no contrails that meet your definition of 'chemtrail'
Why not today? You still haven't got any idea why this is happening or why Sunday is special.
Actually you can, although it's not common. Different models and eras of Jet engines are more or less prone to create contrails because of the temperature of their exhaust. For example all engines are more likely to produce contrails when they are working harder so planes gaining altitude might generate a contrail when a neighbour that is cruising or coming in to land won't.
Don't forget that there is an app available and if you use it when you see a chemtrail you can track it's height and it's constant.
Its almost as if this stuff isn't as simple as you think it is.
Keep googling keep learning, just the other day you never knew planes could be tracked with an app and now you are an aviation expert, fraud.
And yet you haven't done that. Grab a photo next time and a screen grab. If it happens so often it should be easy.
You can do your own and see for yourself, I am not taking a screenshot shot of the map showing where I live thanks.
Anyone can do it, see a plane with the chem characteristics look in the app and check it's height over the entire length of the chemtrail.
They are all over 30k feet. Go and Google if the atmosphere temp, humidity can change massively at those high altitudes, remember same altitude but just 1,000 feet either side front and back
In one very important aspect, the conditions "all over" are "the same".
Too "dry" to form rain.
Too "dry" to form contrails.
The conditions such that some rain is expected are forecast overnight and into tomorrow morning, so let's see.
But don't you see that blows minions argument out of the water. I said I saw 2 planes same height and model cross the same patch of sky how can it be too dry for one and not the other, level flight same aircraft mins apart.
Yep resorting to editing my post when you have lost the debate. :rolleyes:
I have not edited your post.
Which is obvious to anyone blessed with the gift of sight.
I posted it in its entirety, then reposted the part I want to emphasise.
Because on my phone, I do not have the bold function.
And I can't remember the square bracket way to bold text.
Status
