Help with water hammer
20 May 2026
Hello, I’m looking for advice regarding a very loud water hammer issue in my home, which so far no one has been able to explain.
I’ve lived in a 3-bedroom mid-terraced house for the past 15 years. Shortly after moving in, I had a combi boiler installed in the loft and removed the old water tank from the bedroom. The property is mains-fed: the water supply enters from the street at the back of the house, rises in the corner of the kitchen, and runs up the wall to supply the washing machine, dishwasher, and kitchen sink. From there, it runs along the ceiling to feed the toilet, bathroom sink, and bath, before continuing across to the opposite side of the house and up the bedroom wall into the loft, where it supplies the shower and boiler.
The hot water follows a similar route from the boiler, supplying the shower, bath, bathroom sink, and kitchen sink.
A few years ago, while decorating in the bedroom, I found two 22mm hot water pipes connected at both ends, running between the bedroom and bathroom. Assuming this might be why the bath was taking a long time to heat up, I removed one of the pipes. Since then, I’ve had a loud water hammer noise whenever water is used—particularly when turning taps on, rather than off.
I’ve since tried a number of fixes, but none have resolved the issue. So far, I have:
Replaced all pipework (ensuring pipes are deburred for maximum flow)
Installed full-flow isolator valves
Ensured all pipework is laid with a gradient to avoid trapped air
Clipped and secured pipes every 50cm to prevent movement
Replaced the toilet fill valve
Replaced all taps (kitchen sink, bathroom sink, and bath)
Ensured pipes are not in contact with joists, skirting boards, etc.
Insulated all pipework with foam wrap
Installed a check valve and a pressure-reducing valve
Installed multiple water hammer arrestors
Replaced the stopcock
I’ve been told the mains pressure is around 4 bar, and I’ve reduced it to 2 bar using a pressure-reducing valve. However, the banging persists even at the lower pressure.
I do have a couple of theories, though I’m not sure if they’re valid:
Could differences in water density or flow behaviour between horizontal and vertical pipe runs be a factor?
Could there be an airlock in the boiler, given that it sits at the highest point in the system?
Before I spend any more money trying to resolve this, I’d really appreciate any suggestions. Has anyone experienced something similar, and if so, how did you fix it?
These pipes are driving me mad—any help would be greatly appreciated.
Thank you in advance!
Water hammer is primarily down to badly located/run/loose pipework that knocks against itself or something else. When a hydraulic shock is created by a fitting/valve/outlet opening or closing too quickly - usually in higher mains pressure systems - that shockwave then travels along the pipework, find a loose section and the pipe then bangs (hammers) at that location.
Couple options - find the outlet/valve/fitting that creates the shockwave - find the loose pipework and secure it.
Nothing to do with water density/flow behaviour between horizontal and vertical pipe runs I wouldn't think,
Unlikely to be an airlock in the boiler that would create hammer, an airlock would be more likely to cause flow issues.
@Madrab Thank you for taking the time to reply to my post :giggle:
As mentioned previously, I felt I had explored every possible cause of a water hammer issue — I even removed sections of ceiling to confirm that all pipework was clear of joists and properly secured. I’m pleased to say that I’ve finally made some real progress.
The root of the problem turned out to be an air lock around the boiler in the loft. I installed two Automatic Air Vent (AAV) valves: one on the cold feed to the boiler and another on the hot return. Since doing this, the banging has stopped completely.
During my research, I learned that most combi boilers are fitted with AAVs, but only on the central‑heating side of the system. The drinking‑water side relies mainly on mains pressure to push air out through the nearest tap. In my case, the nearest outlet is a rain shower, and the run is simply too long for the mains pressure to clear the trapped air.
This is definitely something to keep in mind if you’re considering installing a boiler in a loft, where it sits at the highest point in the system.
From my experience, if you get a hammer effect when turning a tap off, it’s usually caused by the sudden closure of a valve — a water arrestor often solves this (modern washing machines are a common example). But if you hear banging when turning a tap on, that can indicate trapped air somewhere in the system, and it’s worth investigating further.
I hope this helps anyone dealing with a similar issue.
