Removing Wall Anchors - Help!
13 Feb 2010
Glasgow
These are wall anchor thingies.
I'd like to remove them from the 12mm thick board without wrecking the board.
Any tried and tested way!?
Punch them through.
Use a old screwdriver or something and hammer to punch through.
Fill holes.
Other way is to cut around and put out but hole will be bigger
Use some long nose pliers to pry off the collars.
They are bigger behind plasterboard as they spread out when screwed. Just no way to crush the back part that I know of to allow them to come out.
Plus the plasterboard is soft so you need to hold them to bend..
They aren't very good but that's a problem with plasterboard.
Alternatively you can find a suitably long bolt and screw it into the threaded part of the plug, then knock it with a hammer until the anchor has been extended, then pull it out the wall, effectively reversing the process by which it was fitted in the first place.
Use a HSS bit to drill off the front and the back will then push in/drop into cavity leaving a relatively small hole and four puncture points to fill.
It's the way I've done a few in this house.
