I've found a thread that looks quite similar to what I want to do, but not quite. https://www.diynot.com/diy/threads/remote-humidistat-with-timer-fan.624277/
I've got a Soler & Palau TD-250 Silent T inline fan for my bathroom, and would like it to be controlled in two ways.
-Firstly by a using a Manrose 1361 Humidistat (not using the timer function - I will use the overrun timer on the fan) that turns on the fan when the humidity changes.
-And secondly via a manual wall switch that will bypass the humidistat and turn the fan on and off. (And the idea would be that if the fan is already on because of the humidistat, then turning this switch on or off will do nothing.)
The last diagram on the other thread looks almost like what I want to achieve, except I don't want the light involved that will be on a separate switch.
So if I took the light away from this circuit https://www.diynot.com/diy/threads/remote-humidistat-with-timer-fan.624277/post-5668900
Would this then work in the way I want? And actually is the relay actually not needed any more? As the only reason the relay is in there is to stop the humidistat turning on the light?
