In UK Building Regulations, if you are "disturbing" or renovating more than 25% of the total surface area of an external building envelope (or more than 50% of an individual element like a single wall or roof), the entire thermal element must be upgraded to meet strict modern Part L Fabric Efficiency standards.
Thanks to everybody who has responded, most helpful.
On the above provided by Noseall, it looks as though I am either safe or very close to the boundary.
The works relate to an old extension. Having measured the length of its outer walls, they total 10m in length. The house as a whole though is roughly 45m (detached bungalow), so using this as a basic rule of thumb, I think it's safe to say that less than 25% of external envelope is being disturbed.
The part in brackets may be a problem - the extension has three outer walls. One 5m long but that extended a longer wall, so it is less than 50% overall. The front of the extension wall has a wide patio door flanked by two much narrower piers - I could potentially say the door was never removed, which is feasible and then 50% of that elevation hasn't been affected. The fly in the ointment is the final external wall which is only 1.3m in length. The outer leaf of that being fully replaced!
The inner leaf and roof are remaining exactly as they are.
I think I'm in a bit of a grey area here and it would be extremely harsh for me to be forced to not only improve the cavity insulation, which I am doing, but also renovate with thick plaster the inside of a recently renovated room. On this basis, I will avoid involving BC if I can help it. I've paid them enough fees in recent years to receive what was, frankly, very poor service. This would be yet another 400 quid to come and look at insulation. They don't even provide a duty officer any more so I've had to get advice on here because they won't provide it, apart from pointing me to their website, which is useless in obscure situations like mine. I don't feel any moral compunction on this occasion about just cracking on. The structure will be stronger, better and more energy efficient once I'm finished.
This leaves two final questions: should I get cavity wall batts or Rockwool, or a particular brand? And is it safe to fully fill the cavity?
Thanks again.
