Best method for installing floor joists in new builds?
5 Feb 2012
Salisbury
I'm talking about either cuttings the blocks to height and laying the joist on top or bolting wood to the wall and using jiffy hangers? was wondering if there's a better way in anyone's opinion? Thanks.
Avoid resting heavy joists directly on the lightweight block, use a continuous timber wall plate. You bolt and resin-anchor the wall plate horizontally along the Thermalite wall, and then face-fix standard hangers to the timber instead of the block itself
I use masonry hangers. I know people do it, but the idea of my floor being held up by a dozen bolts stuck in the side of the building equivalent of Weetabix bothers me.
Here's some AI waffle which may or may not be true:
Thanks everyone, a few different opinions but it seems no one likes the sitting it on the blocks option which suits me.
By the way I take it carpenters are getting plenty is work at the moment because it's hard to get anyone to even quote for cutting a roof on this area.
4x2 C24 Plate bedded on mortar on top of the celcon blocks to achieve a level surface, then wall straps at no more than 2 metres apart, wall straps can be hidden by dot and dab plasterboard if that's the wall finish.
I assumed it's the first floor of a multi-storey building.
