Hi, I keep the grout in my kitchen floor as clean as I can and now its time to give it another clean.
I have used the HG grout cleaning before and it was all right but wonder is there any thing else I could use.
I haven't personally used grout sealants. Hopefully someone else will be able to comment.
I have however removed cement grout in the past and used epoxy grout. It is a pig to work with but extremely easy to keep clean- oil/etc will not penetrate it.
