Roof Window - Loose Glass Pane - Internal Repair
30 Jun 2026
I did the yearly test to see if the old attic window still opens and noticed the left pane is loose on three sides on it's metal frame. The attached side being against the metal center. I'm not easily going to have access to the outside of it, but what can I do from the inside to secure it? Would sealant provide the strength to hold it in place as I'm unsure that it would?
4-jpg.417613
Left side of pane
It's going to want cleaning up.
Rust and krud removed.
Treated.. painted.
Glass set back into place.
You could try a hybrid polymer like OB1 for a temporary bodge, but the frame may be too rotten to hold it
