- Joined
- 27 Jan 2008
- Messages
- 29,333
- Reaction score
- 3,608
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I was looking at electric tariffs, most seem to move to BST in the summer, the Economy 7 and 10 seemed to be the odd ones out. I set the time on Tapo smart sockets, for the tariff, and separate summer and winter, but only in 1 hour increments, on the zigbee no summer and winter but ½ hour increments, and as to when midday and midnight are, I would say they don't change with any time change, so always 12:00 and 00:00 UTC summer and winter, so 1 am and 1 pm BST, but others don't seem to agree, so I avoid using midday and midnight.
I suppose midnight is 00:00 UTC + 13 minutes due to being west of the Greenwich line. But this is being pedantic. But with solar power 4:45 am start and 21:30 finish so 7 hrs 15 minutes of non generation, so the mid-point is around 01:37 so 24 minutes out of being a midnight centre, but my panels are on South West facing roof, so that is easily explained.
So in BST my off-peak starts one hour earlier than in UTC, so in BST I never run out of battery, and in UTC I have a double change one less solar, and two the time change, so I will run out of battery far more often.
But I do not want to be ruled by the tariff, ensuring I don't run out of battery at super expensive times, i.e. 4 pm to 7 pm, so I have selected a tariff where payment for export exceeds off-peak tariff, so I do not need to monitor state of charge of the battery to ensure not too high when sun comes out, or does not run out before some high peak charge time.
So time matters, adding an hour or two (I know on the Falklands they added two hours height of summer (our winter)) in the main it is Union rules which causes the problem, as if you start work before 7 am or finish after 11 pm it is considered as shift work or night shift. I remember we wanted an early start on Friday working in Sizewell, so we had an early finish and could beat the traffic build up around Birmingham, but the Union rules resulted in we could not start before 7 am. But if the government changed the countries time, then we could start earlier.
But the cheap electric in the morning, (00:30 to 05:30) offset, means loads of battery reserve off-peak to sun coming up, but a low reserve sun set to off-peak starting.
I do remember the experiment of BST all year around, there was a problem in the North with school children walking to school in the dark. 9 am to 3 pm should be all daylight, and when I went to school it was 9 am to 4 pm, so not sure how that worked? I suppose school children walk slower in the morning to the evening? Always been that way "And then the school boy, with shinning morning face, crawling like a snail unwillingly to school" (As you like it).
But how do we deal with these changing times? Pun intended.
