Removing and replacing Freezer Defrost Heater - Zanussi ZBB28650SA
3 Jul 2010
Warwickshire
Hi there
Anyone know how to remove the freezer defrost heater on a Zanussi integrated fridge freezer - model ZBB28650SA
I had hoped that once I’d defrosted the ice from convectors that had built up, I could just pull it away from the convectors - but that doesn’t seem to be working.
I can see there are three clips on the bottom part of the heater element attaching it to the metal base - but I’ve removed these and it makes no difference.
Also, I can only easily get the the element on the front face of the convectors - no idea how I remove the element from the rear of the convectors?!
Any advice appreciated. Some pics attached.
I don't know the answer.
Surely the pipes running to it from the behind are rigid?
Edit: sorry, only just noticed that the pipes running up look flexible.
The convectors completely ice up over a period of a few weeks and its needs continual defrosting to restore normal freezer function.
I tried testing continuity with a multi meter too and that suggested it may be not be working / or not working as it should.
So did you get it off?
Given that you haven't had much success here, perhaps you should try the following site
If you do get a definitive answer, please post the solution here (this is my support site of choice but sometimes one needs to defer to other sites). In the past they have helped me.
I tried testing continuity with a multi meter too and that suggested it may be not be working / or not working as it should. --------------------------------- What does that mean
Continuity tests will only help if you isolate each of the regular culprits. By way of an example, I was recently asked to fault check an amplifier. I kept seeing continuity... until I removed the L&N running up the PCB. Once I removed them, there was no continuity "down stream". I am not a electrical engineer. I decided that the PCB probably had a faulty capacitor. The fact that the top had started to bulge and that it was loose reaffirmed my "diagnosis".
Continuity tests are useful but are not that reliable.
They are if there is none
Such a simple job to test all the bits five minutes and you've got the answer
