dx90 said:Could some one please explain how my CU is wired/feed so I can understand better?
I think the main power comes into the 100mA RCD and then feeds the 30mA rcd.
YES. A busbar comes out of bottom of the first RCD, and feeds the first set of breakers; and a thick copper link goes from the load side (bottom) of the first RCD to the Supply side (top) of the second RCD. the Neutral from the first RCD goes into the first neutral strip, and a thick copper link goes from here to the Supply side (top) of the second RCD. the Neutral from the bottom of the second RCD goes to the second Neutral strip, and it is very important that the neutrals of all the circuits on that side, go to that strip.
Where can I buy some wylex NSB TYPE B RCBOs?
I have looked and can't fine any.
Not me, sorryi only have MEM! If NSB is still the latest type, it might be this one (sorry not sure) http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=HJMKIUKAPF3ACCSTHZOSFFQ?id=59271&ts=82411 but in any case any electrical wholesaler wil have them, or order them, and might beat the price.
Do I keep the 100mA RCD and just change the 4 MCBs for 4 RCBOs?
If I were you, I would fit a 100A DP isolator instead, once you have the RCBOs fitted. Same source. Say it's for a NSB CU. Wil be about a fiver.
Once I understand it fully and know exactly what I'm doing I will then be able to do a proper job with it.
It is very important to have the power to the CU cut before you do that work. my prefernce is to have a 100A DP isolator in the tails between the meter and the CU so that it can be safely isolated. The suppliers fuse must be out before this is done. Your supplier can probably arrange this for about £60, or might possibly do it free.
MK do a special extra insulation kit specifically for having a TT incomer in a metal enclosure.Taylortwocities said:Richard, the RCD and the 60947 main switch are interchangeable. But JD is correct. In TT the 100mA RCD must preceed any enclosure that is metal.
