110mm waste offset
  • Thread starter Thread starter Rozzachamps
  • Start date Start date
R
Rozzachamps
Hi, I am installing a bathroom in the front of the house but need to get waste pipe to the back of the house, which requires drilling a large hole in the landing wall.
I've drilled the hole however on the other side of it is breeze block!
I'd rather not cut into this too much, so what I need ideally is a small amount of offset in the waste pipe so I can dodge the breeze block. However the only pipe fittings I can find are either pan connector offsets or full bends (which will take up too much space and stick out on the landing).
Are there no small offset connectors available? Or failing that a short (10 inch) flexible pipe section that I can just use to create a very shallow s bend?
