15mm pipe ok for everthing in bathroom?
30 Mar 2011
Yorkshire
is 15mm pipe ok for everthing?
how my new setup will be is
triple valve shower unit with diverter
which will control, bath filler. shower rail, and rain head.
looking at it it has larger inputs for hot/cold than the 3 outputs.
this is going to be installed where the old shower is . i was just going to use the supply from the existing shower for this (15mm)
am i going to have to run 22mm pipe to this instead? say from the old bath supply (as long as this is 22mm)
if its not, does converting 15mm to 22mm pipe somewhere down the run work, or does it have to be 22mm all the way from say the boiler? :confused:
sorry for the completely novice questions
22mm would be your best bet for flow but
its all down to what system you have
if its a combi boiler the hot leaves the boiler in 15mm
r u running shower/bath off of gravity system?
was thy old shower pumped
or have you got pressurised hot water
cheers guys
ive just had a Worcester Bosch 30CDI Combi installed.
removed bath panel this aft. Hots on a 22mm feed, and the cold is on a 15mm :confused:
the existing shower feeds drop from ceiling to shower, i was going to use these. but if its better taking the bath feeds I will use them.
is it worth me converting the bath cold feed to 22mm and run that to control valve (approx 3m way) will this get the flow up?
Clearhead - sorry im not really sure on the answers to those :oops:
shower is plain old thermostatic, ancient thing! dont beleive it to be pumped.
the boiler used to be on the ground floor. now on 1st floor next to bathroom (combi)
to add to this.
since im on a mains fed combi boiler (Worcester Bosch 30CDI)
is that not just ok on the 15mm rather than 22mm?
just rang me BG mate and he said it should be fine. also there is no 22mm cold feed in my house, so im going to struggle
thanks
i think what ben is trying to tell you-it depends on the size of your incoming cold water main
at the end of the day the cold goes into your boiler in 15mm
and comes out in 15mm
and most cwm are in 15mm internally
i would personally use 22 where i can-shortest possible routes(i have heard other plumbers disagree and call us cowboys or lazy for using old 22mm feeds,i have never had a problem and if you ever want to change system back in the future, its all in place-not all clients have the money to start running new pipe works
it will work on either
the boiler will only heat the hot water at x amount of litres a minute around 11 lts a min @ 40 rise
