Just done an extension and have laid sleeved 15mm speedfit under new concrete floor with the best i could get to a 90 degree bend against the wall so have a short run of the pipe vertically against the wall. The combination of dot/dab should result in the pipe from the floor being hidden once skirting board is up so my question is what the best way to get from 15mm plastic that weill be behind final plasterboard to the radiator without too much pipe exposure. I am pretty sure I will end up with an elbow behind the plasterboard so not sure if i should stick with plastic or switch to copper or even 10mm.
Any advise appreciated as not done much with plastic before but was advised its a much better option for burying in screed than copper. Its the "lay flat" version but still pretty stiff and hard to straighten out etc
