15mm Plastic Pipe Bends?
10 Feb 2009
Bristol
Is its ok to sweep plastic water pipe throught 90 degrees if there is sufficient room or is best practice to fit an elbow?
Thanks,
Jon
Yes, although no tighter than 8x the radius iirc.
For tighter bends you can buy formers for about a quid each.
It is actually better this way than elbow fittings.
Use cold forming bends. these will hold the bend so the pipe trying to straighten itself does not exert pressure on adjacent fittings:
COLD-FORMING-BEND.aspx
