thank you.
So much to think about, and not enough time in the day!!!
I will defintely look into the trade paint you mention, and will be posting onto the section too!
If lime plaster has not been used already, and the higher ground is rectified, is matching the already used plaster type good enough?
The walls that are done in this plaster do not all show signs of damp, and therefore I assume that this isn't causing a problem.
