The eves of our loft are already insulated to about 300mm, the middle bit that is boarded and used for storage etc is boards screwed to the rafters ,so only 100mm if any at all.
I've been researching (sorry) my current plan is
Vcl
Insulation up to 300mm
Loft legs and reboard
The plan is lift the boards, clean the area (vacuum) check for nails, lay a vcl over and in-between the joists.
Using batts for the first layer then rolled rockwool type stuff.
The vapour control layer, understanding there are some expensive intillegent membranes out there, would I be ok using the same type of membrane that is under the tiles?
Ta Ray
Vcl
Ta Ray
