Just wondering if anyone would like to offer any thoughts on my situation.
We've had our boiler moved up into the loft. The old boiler and water meter have been removed. The new boiler is supplied by the old water heater radial which is only 2.5mm. Now for the 5 Amps needed for the boiler, I guess this isn't the end of the world even though I understand radials should be 4mm.
While insulating and boarding the loft, I've found the extractor fan that doesn't work and the shaver socket are both powered from the upstairs lighting circuit. The problem I see with this is that the upstairs lighting circuit ISN'T on the RCD side of the consumer unit.
So, as I've got to spend time in the loft extending some of the lighting circuit so it fits over the insulation I thought it might be wise to sort this out as well. The plan is to fit a SELV zone 1 extractor with the transformer in the loft. I don't want to run it off the light switch as we often shower without the light on so I'll fit a separate pull switch for the extractor.
My thinking was to run the boiler, SELV extractor and the shaver socket of the line that now feeds the boiler. My question is, any thoughts on whether I should upgrade the cable to 4mm and keep it radial or should I put in a whole loop of 2.5 mm and have a ring circuit?
While I'm up there doing this, I might put a socket in the loft just in case, after all. It doesn't add much to the job.
Sorry it's a long one and thanks for any thoughts.
