If the ring should close at the same place in the consumer unit, does it have to go all the way back to the consumer unti to terminate or can it joint back anywhere so long as all the sockets are inside the loop?
I'm asking as we had a new boiler fitted and the power is supplied of the old radial line for the water heater that's now gone. However, the new combi boiler only requires 5 Amps.
My plan is to convert this radial into a ring so I can have a spare socket in the loft and the main reason is someone at some point has run the bathroom extractor off the upstairs lighting circuit. I\\\'d feel happier is the fan/boiler and spare socket all ran off one 30 Amp ring.
Does this make sense?
