Hi all
This is my first post and bare with me as I know little.
I have a question regarding the heating in my two story house
I have a boiler and rads
Down stairs in the utiltity there are 2 motorised valves 1 for up 1 for down stairs. Beisde them is a double switch for will turn each of them off/on manually
Across on the other wall facing them is the clock to turn on the boiler.Its a simple pull out the pins to turn on job(off/clock/constant setting on it)
the question I want to ask is.
I want to be able to make the boiler come on lets say during the night for a bit and only heat upstairs as there is no need to heat down stairs but I would also like to be able to have the heat come on down stairs before I get up for work etc.
i had an electrician out at it and it he said it can't be done unless you run new wires back to clock. as this is a 2 story house its a non runner. is there some wireless system out there that would make this work as in turn the boiler on and open/close the motorised valves to suit which zone you want to send heat to.
I hope this makes sense and you might be able to help
