Hi, this has been a long standing problem at my property, but determined to fix it since recent activity. I recently had to replace the ball valve in the header tank. In doing so I drained the system fully to clean half an inch of sludge out the bottom. I should say that the system is old - property built in '64. Whilst the system was drained I removed 3 of the rads downstairs and flushed them through with a hose. Needless to say an awful lot of black water came out of each. On replacing the rads, the same 2 rads refused to heat fully, so no change. The following week I drained the system a further 2 times, changing all 4 valves on the offending 2 radiators. This made absolutely no difference at all. My next plan is to install a Magnaclean on the return pipe before the boiler and add some Sentinal X800 cleaning product - but I fear this will also have little effect. Any comment and advise warmly welcome! Thanks.
