22 to 2x15 tees discouraged?
2 Dec 2013
Dear Experts,
I have a vague recollection that tees with a 22mm “stem” and two symmetrical 15mm “tops” are discouraged because of pressure drop, or something. Or am I imagining that? I think it was probably a post I read here (I can’t imagine where else!).
This is copper CH pipework, at the end of the main 22mm run where it splits under the hall for the last two rooms. A tee with 22mm in and two symmetrical 15mms out “left and right” is the obvious part to use; the alternative would be a tee with 15mm out “left” and 15mm out “straight on” plus a bend or elbow.
This is the part I mean:
https://www.screwfix.com/p/solder-ring-reducing-tee-15-x-15-x-22mm/41389
It's fine.
There's a reason it exists.
How else would you go from 22 to 2 x 15?
Yeah OK guys... You know what I mean.
If the pipe orientation requires it then there's nowt wrong with a 15x22x15
