Hi All,
The old chestnut I suspect...
I want to run F&R through my floor joists and have read up on the permissible hole sizes and where they should be located. I also have a joining room which has the joists running in the opposite direction to the room in question. This means that fortunately I can raise my pipes up in this room and then feed through the joists in the room in question. Hope that makes sense...
I was planning to drill a hole in the first joist, feed the pipe through, mark out where it hits the second joist, drill a hole there and so on... Does this seem sensible and/or is there a more appropriate way of doing this?
Finally, which bit/tool should I use for the whole and what size should I go for given the expansion of pipes.
Thanks in advance.
Thanks in advance.
