26mm bath taps
30 Jun 2005
Hi
I have a set of bath taps with a non standard size of 26mm/1inch tails. Anyone got any ideas how to connect these to my existing pipework
Cheers
Sounds like 3/4" to me, get a 3/4" to 15mm or 22mm adaptor and check.
Thanks mfarrow will check but I'm certain the tails are 26mm as that was the size of the holes I drilled for the bath to accept them
3/4" BSP refers to the inside diameter of iron pipe.
3/4" BSP pipe will have a wall of just over 1/8" giving you 26mm diameter thread.
In plumbing, imperial sizes always refer to bore of old iron pipe, but metric sizes refer to outside diameter.
You buy a 3/4" fitting, the thread diameter will be ~26mm.
