2nd hot water cylinder
Hello would appreciate some fedback on this please , I have a y plan sytem in place , a 115litre hot water tank heated
indirect via boiler , no immersion heater fitted ( could not remove cap , did bot want to risk damage to tank)
ok and i have an abundance of electricity coming form my solar panels .
The easiest opetion for me to utilise this excess electricity is by installing a combination hot water cylinder , hetaed only by the immersion element . I would lik eto fit this in the loft , and when needed , to switch on and say close a gate valve fitted to outlet of existing hwc and then to open outlet of new hwc which will be plumbed into existing hot water supply .
the existing hwc is in the airing cupboard on 2nd floor of the house , the new hwc i propose to install in loft alomost above th eairing cuboard . my question being is this okay to do ? and do i have to have a seperate overflow from new hwc or can i plumb it into existing overflow pipe running along the roof space ?
thanks .
thanks .
