I plan to run all of the cabling to a new joinery shop (3 phase) prior to getting an electrician in to connect everything. I simply need to know what size of SWA cable to run and what the maximum length can be?
I have four machines plated as follows:
Radial Arm Saw - 2.94KW, 4.6Amps, 50Hz
Planer/Thicknesser - 2.2KW, 8.15/4.7 Amps, 50 Hz
Combination Machine - 2.2KW, 8.15/4.7 Amps, 50Hz
Dust Extractor - 3.75KW, 8.5 Amps, 50 Hz
Do I need 2.5mm or 4mm 4core SWA cable?
The longest run from the distribution board to machine would be approx 12 metres. Anything untoward with this?
Thanks in advance,
Jon
Thanks in advance,
Jon
