First you need to advise on its power rating and whether or not the motor can be configured to operate on 3phase-delta connection at 230 volts (i.e. 6 termination studs inside the terminal box)
OK motor will run on 230 volt that's good but what size is it. Horse Power, Kw, amps, give us a clue.
A bit, maybe, but the address looks essentially the same, and the the 'normal' phone number may still work, even though they are now quoting an 0845 one.A bit dated.
