3 port valve change
21 Nov 2009
Oxford
im replacing a 3 port valve at weekend but have very little electrical experience, is it worth leaving alone or should it be like for like?
What have you got, and what are you changing it to? Sorry to be vague, but your not giving us a lot to go on here.
Paul.
Buy the same model as the one you are replacing, and just connect each different coloured wire (5 wires if mid-position valve) to the same corresponding connection as the wire from the old valve.
If you do one wire at a time, you can't go wrong!
