3 Port Valve question/central heating problem
4 Dec 2007
Hi all,
I've got an intermittent problem with my heating thats driving me crazy. It can work perfectly for days, and then I'll get no heating. In order to get it going again I turn off the power to the central heating for literally 5 seconds, and I can hear the 3 port valve wind back under the spring, then all works again perfectly. I've checked the wiring so many times and it all seems correct to the y plan diagram.
I've got a worcester bosch greenstar 25i system boiler, nest thermostat, y plan with a hot water tank thermostat.
Any help would be really appriciated!
Have you thought you might have a dirty system where the 3 port valve is getting stuck?
Do you have a magnetic filter on your system?
Andy
That could be possible I guess. I haven't checked the water in the system tbh, but why would turning off the electric reset everything? Could it be possible that when a combination of h/w on and/or c/h on is causing the valve to move to its furthest position and its not moving back except when the power is turned off, and there is no power on the orange wire?
