I am based in China and have 3 identical 60 meter 220v 1500 w water pumps supplying water up a hill of height about 120 meters and distance about 260 meters. They are currently connected in parallel but the problem is that they are all running at different speeds hence the water is not being supplied as one pump is just running too slow. The rise in height is not the same for each pump, could this be the problem? Any suggestions how these can all be balanced to work at the same speed. Is it easiest just to run separate cables to each putting them on an independent feed but operated from just the 1 switch? If so can they all be connected to a single 32 amp MCB? Many thanks. Tony
