3 way thermostatic mixer- ptfe or silicone
16 Jun 2006
London
hi all
I was just wondering- I have a 3 way mixer valve with 22mm-15mm reducers (combi boiler).
Initially I used ptfe but I have some slight leaks- would I be better off using silicone or something similar. I guess I could tighten them a bit more- they look as though they will be happy to go in about 0.05mm more but I was worried about over tightening.
Cheers
If its a male to female iron type fitting I would redo the joint with more PTFE or even better buy some Loctite 55. If its a compression fitting then I would wrap a bit of PTFE around the olive or if you have some jointing compound use that. I wouldn't advise on using silicone to seal leaks. :lol:
Yep loctite 55. If you do insist on PTFE, at least use gas rated stuff.
And no to silicon or lsx.
Thanks omegaman
Apologies for not being clear- the mixer has threaded 22mm inlets/outlets. I have used brass male to male reducing couplers with ptfe.
I wasn't planning to smear silicone over the leaks but was wondering if I would have been better off with silicone thread sealant in the first place.
Have just had a look at the loctite on you tube- do you roughen the threads first?
Put about 10 turns of std ptfe on it and tighten properly. You won't need anything else.
Hi Tamz
I think that I only used about 5 turns of ptfe- have run out now so will probably try the loctite.
Does any one know if selco sell it or any of the DIY sheds (on a Sunday)?
Haven't a clue. Never used the stuff apart from the free sample they sent me years ago. It is good stuff but i don't see the point of it.
Hi Tamz
Screwfix sell it and are open on a sunday.
thanks- the screwfix site's out of stock and my nearest is miles away.
oh well have to wait till monday... what a shame ;)
