3 way trv
Danfoss, the type your describing is for DHW Part number :-
RAVI KOVM 013U808700 for 15mm or 1/2" bsp pumped primaries
RAVK 013U806300 for 2m sensor range setting 25-65 deg C
Why should you as you are not an installer or repairer?
They are used rather like a blending valve.
Tony
Er.....
Dave, its only YOU who have called it a "TRV" !
Er.....
Err, isn't the title of the thread "3 way trv" :wink:
Does the OP mean TMV? (Mixing/blending valve.) I'd have thought not as he wants a remote thermostatic sensor.
Not a blending valve either , the 3 way is used as a bypass , obviously you have never seen one let alone fitted one......these were used extensively in the 70s/80s on council contracts.
well the engineers on the site knew what he was talking about and directed him straight to 2 options. The googlers turned up and caused confusion as usual. If you don't know, don't post.
blending valve lol, you people :lol:
Both the Danfoss RAVI and the Drayton products have immersion sensors, i.e., they're intended to control water temperature, which isn't what I'd use with a TRV (usually sensing room temperaure).
I think Danfoss do (or did) them, but can't be bothered to root through their catalogue. Send them an e-mail.
