I'm trying to fix a Home cinema projector
but before I steam in, I'd like to run this by other more knowledgable folk.
Background
There are 2 covers that come off to access the bulb and the air filter.
Each cover, when in place/closed, depresses a microswitch.
If the covers are open the unit will not operate and an LED indicates that the covers are open.
Problem
one of the 2 switches (both are on the same tiny PCB) is broken, through repeated careless removal of the flap, so now the unit thinks a cover is off when it isn't and will not operate.
Proposed solution
I can't get hold of a replacement switch board (about 15mm x 40mm)
SO I'm thinking bypass it completey...
It is connected to the unit by a jumper lead with 3 wires. I asume one carries a voltage to the switches, which when pressed, complete circuits to the other 2 wires (one for each switch/cover) which goes back and reports that the covers are in place and alows operation.
IF i simply strip the 3 and twist them together - it should do the trick yes
Background
Problem
Proposed solution
