He's done it because he is an incompetent ***t.Different part of the house- for some reason he's put 4mm in one area and then 2.5mm in another - both are for the same type of light fitting???
Not sure why he's done this
You must put the UFH on hold - it's not just a case of a new electrician seeing what's there, it may also need changing.I have UFH going in next week which will cover up all the remaining cables. It will be very difficult for a new sparky to see what he has done!
He doesn't, and it is going to cost.I am concerned that he doesn't know what he's doing and that fixing it with a new sparky is going to cost me a fortune!
You should take legal advice, you should get a report done by someone who could be an expert witness if needed, and you should gird your loins for taking the incompetent ***t to court.
No.Is it possible to notify BC at this stage and do second fix myself?
