4 way fittings
29 Nov 2018
Hi all
Something I was just curious about, why is it that 4 way fittings are not particularly common? I am talking about something like this:
15mm Copper End Feed Equal Cross 4 Way Plumbing Pipe Fitting (15mm) https://www.amazon.co.uk/dp/B07BPM13WY/ref=cm_sw_r_cp_api_i_a6e8CbWXAS3QN
There seems to be a lot of dubious quality looking ones on amazon and ebay, but nothing on screwfix etc. I found a website selling 4 way compression fittings, but they were £30 something pounds. Is there a reason that they aren’t in general use? Something to do with flow?
Hi all
Heating pipework (flow/return) are usually installed in close proximity to one another so it would be a tad difficult to use a cross tee, same applies with potable pipework (hot/cold), back in the day pipework was installed within notched joists so the use of a cross tee would foul the pipe running parallel to it.
Very seldom were cross fittings used, pretty common to see cross tees used on fire sprinklers.
I've always thought that a corner T would be a useful fitting... All spigots at 90° to each other. Might even exist... Never looked :)
Thanks for the explanation. What got me wondering this is my cold feed comes into my house in the kitchen and then goes straight up the wall to the combi boiler upstairs. I want to put a dishwasher on one side of the feed and a washing machine on the other. Figured a 4 way joint would be the simplest way. Guess ill just use two t joints instead, then!
or just use one of these -
images
