406 estate "P" reg.
26 Jun 2004
London
How can the battery be changed in the plip?
The radio has side light illumination of the controls but the radio/display is not illuminated.
Fuse 16A is OK.
Tony
Where are all the know it alls?
In the peugeot forums?
Yes, but you may have to be quick, on Renault ones if you dont change it within 10 secs you lose everything & need an expensive reprogram :( (so I'm led to believe)
The side light illumination is likely just because there is 12v there.
Does anything work on the radio?
Although I dont understand what these both have to do with each other?
Or are you asking 2 separate things?
