1) Boiler make / model
oil fired, worcester danesmoor 20-25 furnace, bentone electro oil burner
2) What is / is not happening.
burning oil effeciently
3) Has ANYTHING else been done or changed recently.
not that i am aware of only moved in recently
4) When did the problem start?
n/a
5) When does it happen? eg, heating coming on or going off.
n/a
6) Anything else you feel may be of relevance
when i opened the inspection panel on the furnace i noticed that there was only the one baffle in it and only the one set of fixings for this baffle.
On the 7th of february 08 500 litres of oil was delivered to the property (a 4 bedroom detached dwelling) Yesterday i came home to the heating not working first thing i checked was the oil tank, it was empty. is it possible all this oil could have been burned in such a short space of time considering that the heat would only be on a total of four hours a day. What should i be doing to prevent a repeat of this. i am going to check for a leak in the main oil line from the tank,. iam going to change the nozzle. i am going to clean furnace and flue.
any other tips hints and advice would be appreciated
