5mm speed fit too 1/2" hose/tap
17 Jun 2008
Warwickshire
evening all.
was wondering if there is such a thing.
ive got a reverse osmosis filter system that uses all 5mm speedfit piping and conections.
for the feed to the system at the mo ment i only have one of those self piercing type connectors that taps into a hose. problem is it a bit naff and im presuming it lowering the pressure alot and i need all i can get for the sytem to work efficiently.
so i could with a adater that could take 5mm speedfit one end and 1/2" garden hose the other.
is there anything about or and combo of bits i could use?
thanks
ian
3 Dec 2007
Essex
useally what i do on fridges, reverse osmosis etc.
if you t off your cold mains then fit a washing machine isolation valve.
then a 3/4" to 1/4" LLDPE fitting.
the code for the fitting is john guest pt n0 CI320816S.
