I'm looking to modify the wire drive in a SIP 150 turbo (aka it has a fan) welder, which involves using a separate 20VDC supply to drive the wire spool motor.
I have a Dell 65W laptop power supply brick which claims to output 19.5V with a (presumably) max current of 3.33A
The motor expects 20V at a maximum of around 1.5 amps.
I'd plan to physically mount the laptop PSU in the base of the welder where it would be in the airflow from the cold-air fan. The PSU, as most laptop variants are, is a completely sealed device with no holes for airflow.
Do you think it will be comfortable in that environment, given that the fan will be blowing cold air over it? While the welder is on (30-60 minutes at a time) the PSU will be powered up permanently (the DC output to the motor will be switched).
