I need to replace an 8mm heating pipe with 15mm.
The main 22mm pipe where the 8mm starts from is under some laminated flooring. I don’t want to lift up the floor.
My question is: Can I leave a 1 meter length of the 8mm pipe and attach the new 15mm pipe to the 8mm? Will I lose the better flow benefit of the 15mm pipe?
My heating is all 8mm, we have had an extension built and a new radiator installed. The plumber has taken a feed off one of the existing radiators for the new radiator. As a result both radiators do not heat up fully, I have tried to balance them but with little success.
Any help would be greatly appreciated.
