Hi all. I'm looking at having TWO Electric showers fitted at my property. I've seen what i would like and they are 9600 WATT at 230 V. I have a modern 17th edition split Consumer Unit installed already, with space for a couple of MCB's on each side. My supply Fuse is 100 AMP, my Consumer unit has a 100A rated Main DP switch, my supply cable is 25mm SQ. I have this info from my install certificate.
I have a single lighting circuit, two ring mains and an immersion heater (but this is a small type tank - i would have to look in the loft to see what the Power rating is). I want two showers as teenagers will use one all the time and i need another free for myself when i want to use it and not wait for them to get out.
I Will be getting a PART P electrician to undertake the works - I just want some advice on what i may be looking at Technically ( doable with what i have installed already ) & money wise.
Thanks in advance.
Thanks in advance.
