Where is it suitable? I'm boarding & skimming both block and stud walls. I've always used 12mm but a friend uses 9mm. Is there any real difference (apart from 3mm and the cost).
Also, the ceiling joists are on 400mm centres. If using 2.4 x 1.2 x 12mm boards, and the edges don't meet on a joist (ie. there is a 2.4 long length, with the edge 200mm away from a joist) is it okay to have the join between this board and the next not supported by a joist if scrim tape is used?
