Let's have a laugh coming up with daft/scary answers to the questions below...
I used all of my C&G2391 knowledge and hope for a pass
1. You have installed a new radial circuit consisting of 3x socket outlets. The end of the cable is inside the consumer unit, but not connected to anything.
What are the tests you would do, in what order, and how are they done?
ANSWER:
- Check that the cable colour code matches or complements that of the consumer unit.
- Ensure that you don't cover the CPC with any g/y sleeving which may increase capacitance.
- Perform a mutual inductance test to see if everyone is in agreement.
2. Customer has a lighting circuit with 4x pendant lights, the MCB has tripped and won't reset. How do you locate the fault?
ANSWER
Quote to fit a new lighting circuit with halogen downlighters.
3. Customer's house has a CU with 6 circuits (MCB for each), the main switch is a 30mA RCD. The RCD has tripped. The customer has tried to reset the RCD but it will not. Before using any test equipment or tools, what would be the first thing to do?
ANSWER
- bypass the RCD by asking the customer to hold a nail across the both the live and neutral input/output
- If the tripping stops then replace nails with a more permanent solution such as 5 amp fuse wire.
- leave a spare spool of fuse wire with the customer to prevent future call outs.
4. Before any testing is done on a socket outlet circuit in an occupied house, what is the first thing to do?
ANSWER
- Ensure correct functionality by plugging in and boiling kettle.
- If water reaches 90deg C within 4 minutes then socket OK, proceed to live tests.
5. When measuring Zs for a lighting circuit protected by a 6A type B MCB, the results is 3.0 ohms. Is this acceptable?
ANSWER
Yes since it will reduce the current in a fault condition and protect the MCB from tripping.
6. Ring circuit with 10x socket outlets on it. Sockets 1-9 work correctly. When anything is plugged into the 10th socket, the RCD trips every time. What is the most likely cause of this fault?
ANSWER
Socket Trip. Replace socket and/or RCD.
7. When measuring Ze for an installation with a TNS supply, the result is 0.7 ohms. Is this acceptable?
ANSWER
No, the maximum Ze should be 0.8. An appropriate resister must be added and the test performed again.
8. A lighting circuit has several dimmer switches. How will this affect testing?
ANSWER
Testing shall only be performed during the on time of the dimmer triacs.
9. After using a ladder to install a new circuit and outside floodlight at roof level on a 2 storey house, what test would not be done? Why?
ANSWER
- Ensure all rungs are spaced in compliance with IP2X or IPXXB
- Verify the number of story's with a calibrated instrument and probes/leads to GS3.
10. Radial circuit for a cooker. Cooker is not connected, it's a new house. When doing an insulation resistance test, the results are LE 200M, NE 200M, LN 0.25M. What is the most likely cause of this apparent fault? (the answer is not cable damage or trapped wires)
ANSWER
Someone has placed a quarter meg resister across live and neutral instead of damaging and trapping wires. Remove resister then damage and trap wires. Retest ensuring fault has correct causes.
