D
Deleted member 137318
I have just had the lead mains pipe from the street to my house replaced - partly on a quest to improve mains pressure and partly because of the 'lead' aspect. Thames Water incidentially said that I have nothing to worry about because the lead mains pipe would be coated with limescale by now so the chance of injesting lead was neglible (so when a large corporate says don't worry I tend to worry).
Anyway, pipe replaced, the pressure to my new stopcock is now good - well better than it was anyway, (I managed to soak the ceiling just by a cursory quarter turn on the tap so I was happy).
I now need to replace my boiler and wanted to continue this new found pressure right to my bath tub so I was wondering if there are any manufacturers that make boilers with 22mm cold & hot feed. All I have seen so far are boilers with 15mm supplies. Is this possible or am I going to have to reduce it down to 15mm and then back out to 22mm at the bath? Ideally I like it to be a combi boiler as well but understand that I might be asking too much of one boiler
